TwinTurbo.NET: Nissan 300ZX forum - HICAS Removal Question-not the same old question.
Subject HICAS Removal Question-not the same old question.
Posted by sfarrah on June 05, 2003 at 1:42 PM
  This message has been viewed 151 times.
Message After extensive searching i have decided to post this question.
I posted in Tech last night without a single reply so thought i'd try here.
I have removed my HICAS using the Top Speed bar and installed the hydraulic line loop also. What I want to know is if I can block the two outputs from the bottom of the actuator under the hood that run to the back of the car? The Midori kit does not loop the fluid back around, it uses two fittings to block it off at the rear of the car, so why not just block it off at the actuator and not have to worry about any hydraulic leaks running to the back of the car?
Also, is there anyway you can modify the actuator to just always recirculate fluid back to the fluid reservoir by unplugging the electrical connections to it perhaps?
I'd like to remove any hydraulic lines that I have without having to go to an NA pump, bracket, hoses, etc.
Thanks,
Sean
http://www.geocities.com/sfarrah/zpage.html
